01-26-2024
07:08
09:43
01-26-2024
07:08
09:43
Hi there,
I purchased the Versa 3 in December and synced to my iphone 13. However, I've had loads of problems with the bluetooth connection which keeps loosing. I have down the following:
- downloaded all the phone software updates
- downloaded all the fitbit updates under settings
- reset the factory settings, shut down the watch and phone and reconnceted. This has meant the updates have downloaded again.
However the phone keeps loosing the bluetooth connection. I dont have a bluetooth connection problem to my headphones, IPAD, so not sure what to do.
I have fitbit premium so really frustrating. Any help apart from replacing the watch would be appreciated.
01-26-2024 20:45
01-26-2024 20:45
Hi @arvinjeboo - unfortunately this is one of the problems with the new V4 Fitbit App - it is notorious for constantly losing connection requiring manual intervention.
Best Answer01-28-2024 11:41
01-28-2024 11:41
I’m having the same issue. What is the manual intervention required to fix this problem?
Best Answer01-28-2024 11:49
01-28-2024 11:53
01-28-2024 11:53
I was hoping for a permanent fix but I greatly appreciate your help.
