05-04-2021
03:45
20:47
05-04-2021
03:45
20:47
Just updated from charge 2 to Versa 3. So disappointed. Won't stay reliably connected to Bluetooth ,. ( have tried every recommended trick on this site to no avail ) therefore useless to me .. won't connect to Google Assistance .....
I've a One plus Nord phone. No problems with Charge 2.
Any miracle ?
05-04-2021 05:31
05-04-2021 05:31
The problem is they keep updating the app and introducing instability, so may be the Charge 2 will no longer be reliable. That said try disabling battery savings.
On the phone check battery optimizations [the options may be different in your version]
Restart both watch and phone after for good measure - it may help.
05-04-2021 05:39 - edited 05-04-2021 05:41
Hi there, @Parkville. Welcome to the Community Forums. Thanks for trying to troubleshoot the issue with your Versa 3 before reaching out. I understand how you must be feeling. @Guy_ Thanks for your input!
Since you have upgraded from a Charge 2 to a Versa 3, I'd like to know if you've already removed the Charge 2 from your phone's Bluetooth and Fitbit account? If you haven't done so yet, please try the steps below:
As for Google Assistant, may I know more details about the issue? Knowing the issue, I can assist you accordingly.
However, if after following the steps above you are still having issues with Google Assistant, please try the following:
For more information, see How do I use a voice assistant on my Fitbit smartwatch?
Hope this helps.
05-04-2021 15:59
05-04-2021 15:59
05-05-2021 09:56
05-05-2021 09:56
"Why make it so hard to connect/ sort out ? " because Google acquired Fitbit...
maybe try this :
uninstall the app, go to Bluetooth settings and forget all the connection with the watch ( versa3 and versa controls);
Then reinstall the app, connect the watch with the Bluetooth in the fitibit application and restart the watch by charging it.
05-05-2021 12:40
05-05-2021 12:40
I'm having the same problem of being unable to connect to Bluetooth. I have followed your instructions (uninstalling, turning off, reinstalling) etc, but everytime I try to connect to Versa 3 from Bluetooth I get the message "Pairing rejected by Versa 3". And I've tried restarting my Versa 3.
This is my first fitbit and it just arrived today, and to have a problem like this on my first day rather worries me. Can you please advise on what Fitbit is doing about this and what the fix is? thanks.
05-05-2021 13:03
05-05-2021 13:03
05-05-2021 13:15
05-05-2021 13:15
Yes, it connected when I first set up this morning, but since then, nothing. I just tested that it wasn't my phone causing the problem by trying to connect to a different Bluetooth item (a mini speaker) and it worked fine. So it's not my phone, it's Fitbit.
Really hope they get back to us with a proper resolution soon!
05-05-2021 13:45
05-05-2021 13:45
I know your feelings I almost gave up but it's all good now.
The goal is that you phone and the app forget completely your watch in order to set up a brand new pairing with the last version of the app. Their updates caused issues.
i forgot to mention a step during the uninstall process. Before deleting the fitbit app, I went into my account directly in the app, then in the versa 3 section (between "create a family account" and "+ "set up a device"). Now just click on the top right corner (the bin) to remove the Versa3 from your account. Only not synced data will be lost. Please restart your phone before reinstalling the last version of the Fitbit App.
Good luck !
05-05-2021 14:39
05-05-2021 14:39
Thanks for your reply TryDebian.
I tried this as you suggested, including removing Versa3 from my account. Once I reinstall it finds it, it gives me a 4-digit code and I input that, then it just fails to connect and asks me to try again. I did it twice with the same result 😞
This is doing my head in...
05-05-2021 14:41
05-05-2021 14:41
05-05-2021 14:54
05-05-2021 14:54
When you uninstall, you also need to go in the bluetooth settings of your phone and forget the pairing with the versa 3 and versa 3 controls. That would me my first guess. Did you do that Gwenfar ?
05-05-2021 18:19
05-05-2021 18:19
Still having all the same issues and tried all the same remedies. What is going on? So frustrating. Extremely disappointed in this product and I have been a loyal fiybiy customer.
05-05-2021 19:51
05-05-2021 19:51
I hear you Parkville!!! I have had this watch since November 2020 and this I my third Fitbit. I love Fitbit but this issue is really really upsetting. I miss phone calls and texts all the time because my watch doesn't stay connected. I try to answer phone calls that come in to then realize that the google assist on-wrist calls has been disabled automatically. The only thing that helps for me is opening the Fitbit app and syncing throughout the say which isn't the idea. I also need to always be re-syncing it up with bluetooth. I really wish they would fix this!
05-06-2021 00:36
05-06-2021 00:36
05-06-2021 04:29
05-06-2021 04:29
Yes, I did do that with bluetooth settings.
I kept trying a couple more times, then suddenly, it paired! So, yay, but it does drop in and out, so only a little yay. Also, it took c. 3 hours of my day to get to this point. And that's not ok.
So thank you to TryDebian, as I think these suggestions helped. But FitBit need to fix this, both the problem with pairing in the first place, plus the fact even when you do pair, Bluetooth drops in and out, for no obvious reason. No-one should have to spend so much time and energy on getting something so basic to work.
05-06-2021 04:30 - edited 11-16-2023 03:24
Hi everyone, @Gwenfar @magettel @Parkville @Angiemigz. I appreciate you had followed the tips and recommendations provided above. We‘re taking into consideration your comments and sentiments with regards to our products and services. @TryDebian Thanks for your help!
At this moment, I’ve reached the limits of what I can do for you here on the public community forums. The best way to get help for this problem is to chat with us online or give us a call. Click here to get connected.
We hope your issue is solved soon.
06-23-2022 09:47
06-23-2022 09:47
You'd think, but I have a Google Pixel 6 and that won't stay connected either! I have no idea if the problem is with the Pixel's Bluetooth, or with the Fitbit versa 3. Either way it's annoying as all getout
