09-16-2021
21:54
20:43
09-16-2021
21:54
20:43
When syncing my Versa 3 in my app it is asking me to forget my device in Bluetooth and re-pair my watch with my phone ? Why? I Have to do that each time I open my app on my phone.
09-17-2021 01:38
09-17-2021 01:38
Where is it that your being asked?
Have you checked the time of the last sync? You tracker should sync a few times every hour, even without opening.
While you may remove the tracker from the phones Bluetooth. The user will not be able to pair.. Simply opening the fitbit app should prompt the user to ask for permission to pair the tracker.
09-17-2021 07:53 - edited 11-14-2023 11:07
Hi there, @Sunshine1983. Welcome to the Community Forums.
May I know the model of your mobile phone? Please make sure it meets the requirements listed here.
Despite meeting the above requirements, the following devices often exhibit compatibility issues that cause our products and services to not operate properly:
If your phone is not on the list above and meets the requirements to operate properly with the Fitbit app, please try the steps below:
1. Remove the Versa 3 from your phone's Bluetooth settings and in the Fitbit app.
2. Restart your Versa 3.
3. Turn off other Bluetooth connections when not in use.
4. Plug it into the charging cable and open the Fitbit app.
5. Set up your Versa 3.
Hope that helps.
09-18-2021
15:37
16:42
EdsonFitbit
09-18-2021
15:37
16:42
EdsonFitbit
I have an iPhone 8 plus
I disconnected my Fitbit and restarted my phone with Fitbit forgotten on my phone and still have the problem.
Moderator edit: format
09-22-2021 10:00
09-22-2021 10:00
When you say forgotten @Sunshine1983 do you mean that you removed the Fitbit from the Bluetooth?
Removing the tracker from the fitbit app, will only remove the tracker from the fitbit account. We still would need to fix the sync issue.
05-23-2022 07:20
05-23-2022 07:20
@Sunshine1983 Sorry @Sunshine1983 But I think your Bluetooth chip is broken.
05-23-2022 07:24
05-23-2022 07:24
You might have to replace the Bluetooth chip. @Sunshine1983
