01-03-2022 10:42 - last edited on 12-18-2022 20:40 by MatthewFitbit
Hi my versa 3 keeps losing connection daily and i have to go into my phones settings into apps find fitbit and clear cache.. Then i have to log in and set everything back up again to get notifications.... Is this normal
Thanks
01-03-2022 12:23 - edited 12-23-2023 02:57
Hi there, @Rodders73. Welcome to the Community Forums. Thanks for trying to troubleshoot the issue with your Versa 3 before reaching out.
May I know the model of your mobile phone? Please make sure it meets the requirements listed here.
Despite meeting the above requirements, the following devices often exhibit compatibility issues that cause our products and services to not operate properly:
If your phone is not on the list above and meets the requirements to operate properly with the Fitbit app, please try the steps below:
1. Remove the Versa 3 from your phone's Bluetooth settings and in the Fitbit app.
2. Restart your Versa 3.
3. Turn off other Bluetooth connections when not in use.
4. Plug it into the charging cable and open the Fitbit app.
5. Set up your Versa 3.
Hope that helps.
01-04-2022 00:12
01-04-2022 00:12
My phone is a huawie p20 pro
