07-10-2022
04:39
17:50
07-10-2022
04:39
17:50
I know it's still beta but Android 13 make it almost impossible to use my fitbit versa 3
Every few hours i need to restart my phone to get my versa to reconnect
All the other Bluetooth device are working versa is not the only watch to have this issue according to a Reddit post
07-10-2022 09:23
07-10-2022 09:23
I'm on Android 13 beta and while there were some issues with randomly dropping bluetooth that appears to have been mostly resolved. I had the same issue with wifi. Did you download the latest beta update?
07-14-2022 08:37
07-14-2022 08:37
Tpb4 looks promising until now but it was just released yesterday and this is an intermittent issues
07-14-2022 09:30 - edited 04-26-2024 05:58
Hi there, @Kgelinas. Welcome to the Community Forums. Thanks for trying to troubleshoot the issue with your Versa 3 before reaching out. I understand where your concern is coming from. @SunsetRunner Thanks for your input!
If the issue you're experiencing seems to be intermittent, may I know the model of your mobile phone? Please make sure it meets the requirements listed here.
Despite meeting the above requirements, the following devices often exhibit compatibility issues that cause our products and services to not operate properly:
If your phone is not on the list above and meets the requirements to operate properly with the Fitbit app, please try the steps below:
1. Remove the Versa 3 from your phone's Bluetooth settings and in the Fitbit app.
2. Restart your Versa 3.
3. Turn off other Bluetooth connections when not in use.
4. Plug it into the charging cable and open the Fitbit app.
5. Set up your Versa 3.
If you're getting an error message in the Fitbit app, may I know what it says?
07-15-2022 06:39
07-15-2022 06:39
My phone is a pixel 5
Already tried it
Already tried it
Really???
Tried it
Already tried most of the time i need to restart my phone to pair my watch.
I'm not the only one with this issues even with the latest beta which is the last
07-15-2022 09:13
07-15-2022 09:13
Did you submit a bug report to Google?
