09-17-2022
02:15
17:12
09-17-2022
02:15
17:12
Nearly every single day my versa 3 loses connection. I follow every single advice and sometimes in order to regain connection I need to uninstall the app, re-install it, forget versa3 and reconnect. It works for a day or 2 and then it gets disconnected again. It's just not worth the trouble
09-17-2022 04:45 - edited 08-18-2023 05:29
Hi there, @Fd66. Welcome to the Community Forums. Thanks for trying to troubleshoot the issue with your Versa 3 before reaching out. I understand where your concern is coming from and how you must be feeling.
May I know the model of your mobile phone? Please make sure it meets the requirements listed here.
In addition to the steps you've done so far, I suggest trying the following:
