09-17-2022
19:39
17:12
09-17-2022
19:39
17:12
My versa 3 does not stay connected to my phone. It's a nightmare compared to versa 2 that died while I was swimming.
09-17-2022 20:48 - edited 09-17-2022 20:49
Hi @SiskSiskg - have you tried logout of the app and restarting both watch and phone.
Also check phone battery optimization Settings isn't shutting down either Bluetooth or the Fitbit App.
09-18-2022 11:44 - edited 11-21-2023 05:56
Hi there, @SiskSiskg. Thanks for stopping by in the Community Forums and sharing the details about the issue with your Versa 3. I understand how you must be feeling. @Guy_ Thanks for your help!
While reading your posts above, I was wondering if you did remove your old Versa 2 from your Fitbit account and phone's Bluetooth settings?
It seems that your Versa 3 cannot connect properly to your Fitbit app since you haven't yet forgotten the connection between your old watch and the phone's Bluetooth which would explain the connectivity issues you're running into. With that said, try the steps below:
If the issue persists after trying the above, please see Why won't my Fitbit device sync?
Hope that helps.
09-18-2022 16:58
09-18-2022 16:58
Have tried everything. Eventually connects to Bluetooth but then disconnects again!
Very frustrating. No on wrist calls no Alexa!
09-19-2022 00:32
09-19-2022 00:32
I'm having the same issue. Have done everything the Moderator said n it still connects n then disconnects. It does it 3 times over again n then stops. It won't stay connected.
10-04-2022 13:19
10-04-2022 13:19
Yes mine is doing the same thing. It is connected and then not connected. Also when I try to set up Wi-Fi it says network not found.
10-07-2022 05:58
10-07-2022 05:58
Same with me and when I take it off to charge it - The Who watch display resets itself to something I don’t want and I can’t seem to rest it!! Does anyone know how to fix this issue?
