Versa 3 won't stay connected to my phone's Bluetooth
ANSWERED
My versa keeps disconnecting from my phone, the symbol appears on my versa screen, I don't get notifications through to my versa, also the battery needs charging every 3 days is this normal for this watch, only a couple of weeks old! Couldn't find anything in manual or here
1 BEST ANSWER
Accepted Solutions
Hi there, @Eiths. Welcome to the Community Forums. Thanks for the details provided in your post about the issues with your Versa 3.
Please note that Versa 3 Controls might be listed as “Not Connected” in the list of Bluetooth devices on your phone. When you receive a phone call, the controls automatically reconnect. This feature requires more frequent charging.
Nevertheless, I'd recommend trying the following steps:
  • Unpair your Versa 3 from your phone's Bluetooth and Fitbit app.
  • Unpair other Bluetooth devices that you may also have paired to your phone's Bluetooth settings.
  • Force quit the Fitbit app.
  • Turn off other Bluetooth connections when not in use. This can help to prevent connectivity issues or Bluetooth interference.
  • Turn on the Bluetooth on your phone.
  • Plug it into the charging cable and open the Fitbit app.
  • Set up your Versa 3.
  • If there is no connection, restart your Versa 3.
  • Once your Versa 3 is paired and syncing, please proceed to set up your other Bluetooth devices to your phone again.
With the steps above, what I want you to do is to pair your Versa 3 first to your phone's Bluetooth settings before any other Bluetooth device is connected to your phone.
Regarding the battery, are you using Snore Detection? If so, please note that the Snore Detection feature does impact your device’s battery, so we recommend charging your device to at least 40% before going to bed. For more information, see How can I use my Fitbit device to detect snoring and noise levels while I sleep?
However, I'd like to share with you that the battery life will depend on how frequent certain features are used in general. Because you're using an Always-On Display clock face, I'd recommend changing the clock face to another one made by Fitbit and monitor your it's behavior in the next day. Additionally, try turning off this setting by opening the Settings app on your watch > Display > Always-on display.
1 REPLY 1
