02-20-2023
00:05
06:14
02-20-2023
00:05
06:14
I have had my Versa 3 about 2 weeks now and i have already found three problems with this watch. Two of them have been resolved but one hasn't. The Fitbit app is stuck on looking and every time I have to setup the device again which takes quite long.
I hope this will be fixed soon or someone could reply cause its really annoying me.
02-20-2023 06:16 - edited 10-18-2024 08:27
Hi there, @Ariace3. Thanks for stopping by in the Community Forums and sharing the details about the issue with your Versa 3. @Guy_ Thank you so much for your help.
I'd recommend trying the following steps:
Best Answer02-20-2023 00:22
02-20-2023 00:22
Hi @Ariace3 - this seems like a phone or previous watch issue.
Logout of the Fitbit App, swipe off the active window and in Android clear the storage cache and force stop it. Remove the Bluetooth entries for the Versa 3 from the phone.
Then restart both watch and phone, login to the Fitbit App and wait for the pair and link prompts and sync.
If that is not working, click profile photo, make sure only the Versa 3 is shown, click "+ Set up a device" and replace.
If this doesn't work mention what is the problem in more detail or you can chat via the Fitbit App, click profile photo, Help & support, Contact Customer support.
Best Answer02-22-2023 00:03
02-22-2023 00:03
I have done all of the above, and it works but it doesn't fix it permanently. It still says looking after a few days after I fixed it. Please let me know if there's a way to resolve this permanently.
