03-26-2022
		10:07
		20:14
		03-26-2022
		10:07
		20:14
My versa 3 will not sinc. It says I need to have nearby permissions set, and I have messed it with for over two hours it will not sinc. I can't find nearby permissions in the app. I have uninstalled 3 time and this has not helped at all. I am in a step bet and need it to sinc today! Please help!
03-26-2022 12:20 - edited 03-05-2024 06:57
                                          Community Moderators ensure that conversations are friendly, factual, and on-topic. We're here to answer questions, escalate bugs, and make sure your voice is heard by the larger Fitbit team.  Learn more
Hi there, @PrettyPaws1980. Thanks for stopping by in the Community Forums and trying to troubleshoot the issue with your Versa 3 before reaching out. I understand where your concern is coming from.
May I know the model of your mobile phone? Please make sure it meets the requirements listed here.
If you haven't done so yet, I'd recommend taking a look at these help articles Why is the Fitbit app prompting me wo turn on location services?, What should I know about using the Fitbit app on my Android phone? and Why won't my Fitbit device sync?
Hope that helps.
Was my post helpful? Give it a thumbs up to show your appreciation!  Of course, if this was the answer you were looking for, don't forget to make it the Best Answer! Als...
 Best Answer03-26-2022 12:20 - edited 03-05-2024 06:57
Hope that helps.
 Best Answer03-26-2022 12:40
03-26-2022 12:40
It's an a Droid s21 with 5g. It's worked just fine until 11:54pm past night. I read all those articles. it's not working.
 Best Answer03-26-2022 21:55
03-26-2022 21:55
Having the same problem
 Best Answer03-27-2022 16:34
03-27-2022 16:34
Im having same problem is there a resolution yet ?
 Best Answer03-28-2022 05:54 - edited 12-27-2023 04:30
@PrettyPaws1980 I appreciate you had followed the tips and recommendations provided above.
@lovmy8k9s @Sh9 Thanks for stopping by in the Community Forms. If you've also followed the tips and recommendations I provided here as @PrettyPaws1980 did, the best way to get help for this problem is to chat with us online or give us a call. Click here to get connected.
We hope your issue is solved soon.
