Versa 3 won't sync to my phone
ANSWERED
Not able to sync versa3 with mobile after reset
1 BEST ANSWER
Accepted Solutions
Hi there, @Kamakshi. Welcome to the Community Forums. Thanks for trying to troubleshoot the issue with your Versa 3 before reaching out.
May I know the model of your mobile phone? Please make sure it meets the requirements listed here.
Despite meeting the above requirements, the following devices often exhibit compatibility issues that cause our products and services to not operate properly:
  • Huawei P8 Lite
  • Huawei P9 Lite
  • Xiaomi Mi 6
  • Huawei P20 Lite
  • See these additional instructions for help resolving any issues using the Fitbit app on this device.
If your phone is not on the list above and meets the requirements to operate properly with the Fitbit app, please try the steps below:
1. Remove the Versa 3 from your phone's Bluetooth settings and in the Fitbit app.
2. Restart your Versa 3.
3. Turn off other Bluetooth connections when not in use.
4. Plug it into the charging cable and open the Fitbit app.
5. Set up your Versa 3.
Hope that helps.
2 REPLIES 2
  • Huawei P8 Lite
  • Huawei P9 Lite
  • Xiaomi Mi 6
  • Huawei P20 Lite
Hope that helps.
Tried everything I was told. Still didn’t work. Will not buy another. They tell me it’s defective warranty is up so that’s it
