Versa 3 won't track my sleep data accurately
ANSWERED
I noticed my Versa 3 stopped tracking my sleep since Friday. I’ve restarted it a couple of times but still it’s still not responding. Meanwhile, I noticed the green light that blinks behind the watch (sensor) doesn’t show but every other thing works.
1 BEST ANSWER
Accepted Solutions
Hi there, @Mozigi. Welcome to the Community Forums. Thanks for trying to troubleshoot the issue with your Versa 3 before reaching out here.
I've seen you contacted our Support Team after posting here. If you still need help, please feel free to contact our team back.
Hello, @TropicalFluffWe‘re taking your comments and sentiments in regards to our products into consideration.
I recommend considering the following in order to get sleep stages:
  • If you slept in a position that prevented your device from getting a consistent heart-rate reading or wore it too loosely. For best results, wear your device higher on your wrist (about 2-3 finger widths above your wrist bone). The band should feel secure but not too tight.
  • If you used the Begin Sleep Now option in the Fitbit app (instead of simply wearing your device to bed). For more information on automatic sleep tracking, see How do I track my sleep with my Fitbit device?
  • If you slept for less than 3 hours.
  • If your device’s battery is critically low.
For more information, see What should I know about Fitbit sleep stages?
2 REPLIES 2
My Versa only records some of my sleep. I usually get up in the night at least once to use the bathroom. After that, it doesn't record the rest of my sleep.
Right now, I need accurate records for my doctor, but the Versa is showing that I'm only sleeping 3-5 hours per night, which can't be right.
