05-05-2022 11:01 - edited 12-18-2022 19:55
I go to sleep at 9pm, usually asleep by 930pm, my sleep tracker is never correct. Sometimes its 1130, 1212, 1115 its all over the place. How do i get a correct sleep record?.
05-06-2022 03:56
05-06-2022 03:56
Hello there, @SunsetRunner. Welcome to the Community Forums. Thanks for the details provided in your post about the issue with your Versa 3. I understand where your concern is coming from.
As a first approached, I'd recommend to sync your Versa 3 to the app after waking up. This will help to make sure that all your data is sync properly.
Also, note that your time asleep is calculated by subtracting your time spent awake and restless from your overall tracked sleep time. For example, if you slept 8 hours but woke up 2 times for 15 minutes each, your time asleep would be 7 hr 30 min. For more information, see How do I track my sleep with my Fitbit device?
To learn more about your time asleep in sleep stages, see What should I know about Fitbit sleep stages?
Hope this helps.
05-06-2022 14:02
05-06-2022 14:02
Mine stops tracking after 2am. Has happened the last 3 nights and has never happened before. Was there an update to either the app or firmware in the last 3 days?
05-06-2022 15:00
05-06-2022 15:00
05-06-2022 15:56
