01-19-2022
13:07
20:34
01-19-2022
13:07
20:34
My Versa 3 is not working at all. Not even charging, completely dead.
01-20-2022 05:19 - edited 11-13-2023 11:19
Hi there, @AdrVera. Welcome to the Community Forums. Thanks for the details provided in your post about the issue with your Versa 3.
As a first approach, I'd to try restarting your Versa 3. For instruction, see How do I restart my Fitbit device?
If the restart doesn't work and you haven't felt a vibration on your watch during this process, I recommend trying the following steps:
Hope that helps.
01-19-2022 21:32
01-19-2022 21:32
Hi @AdrVera - if its not charging the battery will be flat. Often cleaning helpg or it could be a common with charger - see instructions How to check charge cable - Sense/Versa 3 won't charge, won't start or blank screen
Hope that helps.
