01-28-2022
14:06
20:34
01-28-2022
14:06
20:34
Versa 3 stopped working at although it was charged; charged it then an exclamation mark appeared, now screen black and unresponsive. Have cleaned the connection points. Still unresponsive
01-29-2022 04:26 - edited 04-20-2024 06:42
Hi there, @kiterman. Welcome to the Community Forums. Thanks for trying to troubleshoot the issue with your Versa 3 before reaching out.
As a first approach, please try restarting your Versa 3. For instruction, see How do I restart my Fitbit device?
If the restart doesn't work and you haven't felt a vibration on your watch during this process, confirm that you've tried the following steps:
If none of the above has done the trick, the best way to get help for this problem is to chat with us online or give us a call. Click here to get connected.
Best Answer01-28-2022 23:06
01-28-2022 23:06
Hi @kiterman - there can be issues with the charge cable but check all the things to verify in How to check charge cable - Sense/Versa 3 won't charge, won't start or blank screen
Best Answer01-29-2022 04:26 - edited 04-20-2024 06:42
