03-04-2022
05:05
20:21
03-04-2022
05:05
20:21
My Versa 3 suddenly died. It went to a black screen, even though still had charge, and now it doesnt charge. I tried plugin it on my PC or in a wall socket and it does not charge.
03-04-2022
07:51
07:08
03-04-2022
07:51
07:08
Hi @lfdepippo - don't despair this is quite a common problem which can be due to the watch contacts needing cleaning or a fault with the charge cable, see How to check charge cable - Sense/Versa 3 won't charge, won't start or blank screen
There are many features on the watch that can drain the battery quite quickly. If you want to extend the time between charges once you get it charging again see How to resolve the Major issues causing short battery life.
Best Answer03-04-2022 08:30 - edited 06-10-2023 10:48
Hi there, @lfdepippo. Welcome to the Community Forums. Thanks for trying to troubleshoot the issue with your Versa 3 before reaching out.
I've seen you contacted our Support Team after posting here and they're now helping you.
