07-14-2022
07:32
17:44
07-14-2022
07:32
17:44
Hello!
I’ve had quite a few problems with my Fitbit versa 3 and it never seems to be working correctly.
Does anyone else have endless issues with their Fitbit? Honestly I’m really disappointed by how many I’ve had with the Fitbit.
07-14-2022 09:25 - edited 07-01-2023 10:34
Hi there, @Jennykim. Welcome to the Community Forums. Thanks for trying to troubleshoot the issue with your Versa 3 before reaching out. I understand how you must be feeling.
In addition to the steps you've done so far, I suggest trying the following:
If you manage to bring your Versa 3 to life, but the battery keeps draining, may I know if you're using Snore Detection? If so, please note that the Snore Detection feature does impact your device’s battery, so we recommend charging your device to at least 40% before going to bed. For more information, see How can I use my Fitbit device to detect snoring and noise levels while I sleep?
However, I'd like to share with you that the battery life will depend on how frequent certain features are used in general. Because you're using an Always-On Display clock face, I'd recommend changing the clock face to another one made by Fitbit and monitor your it's behavior in the next day. Additionally, try turning off this setting by opening the Settings app on your watch > Display > Always-on display.
If none of the above has done the trick, as @N8teGee has suggested, the best way to get help for this problem is to chat with us online or give us a call. Click here to get connected.
Best Answer07-14-2022 08:10
07-14-2022 08:10
