08-21-2022
17:36
17:25
08-21-2022
17:36
17:25
Hi all. My versa 3 is totally unresponsive. It does not charge, it does not vibrate, the green lights that light up on the back when charging are not on. I tried resetting by holding the ‘button’ for 10 seconds and then even longer and nothing happens at all. It’s like it’s completely dead but isn’t charging either. On my phone, it says the battery is at 22%. Please help! Is there another way to reset? Factory reset? Anything?
08-22-2022 09:17
08-22-2022 09:17
Hi there, @FLsunshine1234. Welcome to the Community Forums. Thanks for trying to troubleshoot the issue with your Versa 3 before reaching out. I understand where your concern is coming from.
I've seen you contacted our Support Team after posting here and they've already assisted you. If you still need help or have any questions/concerns regarding the outcome of your case, please feel free to contact our team back for further assistance.
Hope that helps.
08-22-2022 09:25
08-22-2022 09:25
Hi! I'm having the exact same issue and when I chatted with someone yesterday, they told me that someone would reach out to me via email, but I've yet to receive anything. Please help! Thanks
08-22-2022 09:29
08-22-2022 09:29
Hello, @emgee3. Welcome on board. Thanks for the details provided in your post.
Please note that your case was forwarded to our higher tier of support for further checking. Someone will be in contact with you soon as they have the resolution for your issue. It seems that our Support Team has exhausted all troubleshooting steps availed for this issue, so there's nothing left we here in the community can suggest.
Thanks for your understanding. Have a nice day!
08-22-2022 11:49
08-22-2022 11:49
My Versa 3 is doing the exact same thing. What do I do next?
08-22-2022 15:59
08-22-2022 15:59
Hi there, @lattinmr. Welcome to the Community Forums. Thanks for the details provided in your post.
As a first approach, I recommend restarting your Versa 3 as suggested here How do I restart my Fitbit device?
If the issue persists, please try the following:
Hope this helps.
08-22-2022 17:00
08-22-2022 17:00
Same here. These watches just don’t last. I have tried 3 different ones and all stop working in less than a year.
08-22-2022 17:04
08-22-2022 17:04
Mine is having the same issues
08-22-2022 17:52
08-22-2022 17:52
Mine is having the same issue and I’ve noticed that they attach a link for how to restart your device with each answer but the versa 3 is not listed in the devices that they give instructions for, so it’s not really helpful and I’m still in sure how to restart. It really shouldn’t be this complicated!
08-22-2022 19:31 - edited 08-22-2022 19:36
yes, I called customer service and they told me that it was still under warranty and would replace it. They sent an email with a form to fill out for the replacement. I got an email saying they received the form and will update me soon... haven’t heard anything since then. Wondering how long it will take for replacement to get here.
also, they said I didn’t need to send the broken watch back, which I thought was a little strange ...?
08-22-2022 20:36
08-22-2022 20:36
Mine is doing the same thing and I am unable to reach live chat
08-23-2022
01:08
10:56
08-23-2022
01:08
10:56
Hi all, some issues have been reported that the watch doesn't charge after a firmware update, it can also happen if it got water in it.
However, it is most likely a charge cable fault or the watch needing proper cleaning, see how to resolve in How to check charge cable - Sense/Versa 3 won't charge, won't start or blank screen
