12-19-2022
05:46
12:14
12-19-2022
05:46
12:14
Hello. The wife's Versa watch, gold color, powered OFF and will not power ON since Sat Dec 18th. It was purchased Aug 15th 2021. Is there a method to resetting it?
12-19-2022
07:34
07:47
12-19-2022
07:34
07:47
Hi @Jonathank1978 - it may be simply a matter of charging it. Sometimes they don't charge well or at all, see here how to deal with it. How to check charge cable - Sense/Versa 3 won't charge, won't start or blank screen
Of course it may be something else, so post back if it's not fixing it.
Your post has been moved to the Versa 3 forum where such matters are posted.
12-20-2022 23:38
12-20-2022 23:38
If your Versa 3 display is unresponsive, try restarting it by doing the following: Press and hold the button for 10 seconds until you see the Fitbit logo on the screen, and then release the button.
Regards,
Will
12-21-2022 06:14
12-21-2022 06:14
All of those steps, failed. The disoplay occasionally goes on with 0% battery. The charger for my Fitbit Sense works perfect, just not for hers.
12-21-2022
06:20
07:47
12-21-2022
06:20
07:47
@Jonathank1978- it show signs of a failed factory reset for which there is nothing to be done. It will show 0% when the battery is flat and nothing if there is a charge on it. You can verify this by charging using a PC and listen to the connect / disconnect sounds which will probably be repetitive.
If that is not the case post back again.
