06-24-2024
22:16
04:42
06-24-2024
22:16
04:42
My Fitbit Versa screen started to flicker and went blank. I tired to resstart and factory reset but the logo does not appear. Unfortunately I deleted the device from my app and I cant try the change clock face.
06-25-2024 04:48
06-25-2024 04:48
Hi there, @CandleK. Welcome to the Fitbit Community Forums. Thanks for bringing this to my attention and for the troubleshooting steps you've tried. I'm sorry to hear that your Versa 3 is still unresponsive. I understand your concern, I will do my best to help you with this!
To better assist you, may I know if your Versa 3 is vibrating while trying to perform the factory reset? It sounds to me that your Versa 3 has run out of battery.
Please note that sometimes a Fitbit doesn’t seem to be charging when actually the issue is that it has become unresponsive (this can happen if the battery has been allowed to discharge completely). I'd recommend putting it on to charge on a charging wire and outlet known to be working. Leave it on the charger for a good two hours, even if it doesn’t seem to be charging.
When it has had two hours, try restarting your Versa 3. I would recommend trying this maybe twice in a row if a first try doesn’t work.
If the above doesn't work, please see Why isn't my Fitbit device's battery charging?
Once the above has been done, let's try once again the factory reset. Important: Take into consideration that a factory reset deletes any stored data, which includes all data that hasn't synced to your Fitbit account and your applications, alarms, etc.
With the above being said, please sync your Versa 3 and then, proceed with the steps below in the order listed:
Once the above has been done, you can now proceed to set up your Versa 3 again by following the steps provided here How do I set up my Fitbit device?
07-02-2024 22:33
07-02-2024 22:33
Thank you. I have followed the steps including fully charging and resetting. I can feel the vibrations but there is nothing on the screen.
