05-13-2022 10:32 - last edited on 12-18-2022 19:58 by
Received a firmware update request on my Versa 3 but since then the device simply doesn't startup. The download completes, but the installation fails and the device simply doesn't start anymore.
05-13-2022
11:28
09:42
05-13-2022
11:28
09:42
Hi, @arijit89 if you have tried this several times and it still doesn’t work the best thing to do would be to get in touch with Fitbit Customer Support and they will help you. It is possible that a factory reset could fix this issue, but it is best only to do that under instructions from Customer Support. You can reach them on Contact.Fitbit.com
Welcome to the forums!
05-13-2022 19:55
05-13-2022 19:55
