08-24-2022
20:07
17:20
08-24-2022
20:07
17:20
Versa 3 not vibrating or notifying me when I reach my 7500 step goal.
08-24-2022
23:29
08:55
08-24-2022
23:29
08:55
Hi @Fishmoose - did you sync the watch with the Fitbit App since changing the step goal?
Also check that the watch is not in do not disturb or sleep mode as it may not notify you. Swipe watch face to the right to get to Quick Settings to check.
Lastly set vibration to strong in the watch settings and keep your watch charged, as vibrations are very weak and get weaker as the battery levels falls and you may not notice if it does alert you.
Best Answer08-25-2022 04:55 - edited 04-01-2024 13:27
Hi there, @Fishmoose. Welcome to the Community Forums. Thanks for the details provided in your post about the issue with your Versa 3. @Guy_ Thanks for your help!
I've seen you contacted our Support Team after posting here and they've already assisted you. If you still need help or have any questions/concerns regarding the outcome of your case, please feel free to contact our team back for further assistance.
Best Answer08-28-2022 06:38
08-28-2022 06:38
I have tried all suggestions mentioned in the forum and provided by Fitbit customer support, but I am still not being notified when I reach 7500 steps. All other notifications work. Thanks to all who tried to help.
Best Answer08-28-2022 07:19
08-28-2022 07:19
@Fishmoose Did you double check that the step goal is set for 7,500 and not 10,000?
08-28-2022 07:20
08-28-2022 07:20
@Fishmoose Another thing you can try is set your step goal lower, like 5,000 for one day. See if it vibrates at 5,000 for that day. Then adjust it back to 7,500 the next day and see if it will vibrate for you.
