07-16-2022
16:32
17:47
07-16-2022
16:32
17:47
My verse 3 doesn’t vibrate when I need steps or when my phone rings
07-16-2022 23:26
07-16-2022 23:26
Hi @Linda.kessinger.
Have you checked to see if do not disturb mode or night time mode is turned on. You can do this by swiping to the left of the clock face to bring up the quick settings screen. Make sure that the DND and Moon icons are not highlighted.
07-17-2022 07:49 - edited 06-14-2023 03:39
Hi there, @Linda.kessinger. Welcome to the Community Forums. Thanks for the details provided in your post.
Is your Versa 3 not vibrating at all? I was wondering if your Versa 3 does vibrate with your silent alarms? Your watch vibrates to alert you at various times, including if you set an alarm, when you hit your step goal, or if you haven’t met your hourly activity goal. Have you see if the vibration is also missing for these features?
If your Versa 3 didn't alert you, make sure you successfully set an alarm. For more information, see How do I manage alarms on my Fitbit device?
If you correctly set the alarm or aren’t receiving other alerts, test your device’s vibration motor. Connect the device to the charging cable. For more information, see How do I charge my Fitbit device?
Also, as @N8teGee has mentioned, note that when you turn on the Do Not Disturb, Quiet hours, or Driving mode setting on your phone your watch receives notifications, but it won’t alert you. For more information, see How do I navigate my Fitbit device?
12:03
07:11
07-17-2022
12:03
07:11
Turn off or restart your Fitbit device
Moderator Edit: Formatting
07-18-2022 18:17
07-18-2022 18:17
Both are in correct positron but still won't vibrate - especially for alarm mode.
I have checked the settings and have it on the strong mode for vibration. I just get the zzzzz but no vibration.
07-18-2022 18:37
07-18-2022 18:37
Hi @Nannyjoan - you can thoroughly test the watch vibration, it has 8 types, using the SimpleVibrate app.
Some of them are very weak even on the strong setting which you can choose from the watch Settings menu.
It could also be the watch has a fault.
But first try a sync and do a full Shutdown from the watch Settings menu. Wait at least 10 seconds before placing on the charger to restart it and charge it and check vibration again.
You can chat via the Fitbit App, click profile photo, Help & support Contact Customer support.
07-18-2022 18:40
07-18-2022 18:40
None of these hints worked.
What else can I try?
Regards,
Joan
Best Answer07-18-2022 18:44 - edited 07-18-2022 19:43
@Nannyjoan If your Versa 3 battery level is low, it won’t vibrate. It also will not vibrate in Do not disturb (DND) or sleep mode, or focus mode. Also check on your phone that share system notifications is on, and you don’t have DND on.
07-18-2022 18:59
07-18-2022 18:59
@SuperMr.M- as you are new to the forums, to help understand who your valid point is for please type the "@" and select the name of the person you wish to reply to.
You can also correct your posts by clicking on the 3 dots, then Edit, or possibly a hidden box on the date line of your posts [on a mobile].
07-18-2022 19:09
07-18-2022 19:09
Bingo. When all else fails restart and it worked straight away. Thank you.
Regards,
Joan
07-18-2022 19:45
07-18-2022 19:45
@Guy_ So sorry about that… I’m fairly new to the community and got a little ahead of myself! So sorry.
07-18-2022 22:22
07-18-2022 22:22
@SuperMr.M - it's ok, you already mastered it. Bravo.
