02-06-2021
11:07
20:47
02-06-2021
11:07
20:47
I bought a Versa 3 and the large wristband is very tight on the last notch. I have bought and returned 2 different XL bands off Amazon. Neither one would work with the Versa 3 quick disconnect feature. My wrist is about 9” around. Does anyone have recommendations on where I can find a band that will work with the Versa 3 and fit around my wrist?
02-08-2021 14:27
02-08-2021 14:27
@Smorell82689 you may have to change Amazon to the USA store.
Another option would be something like this. Links cans be easily added but it may mean buying a second band.
02-06-2021 15:02
02-06-2021 15:02
Hi @Smorell82689,
I have large wrists too and I buy my bands off of eBay. I've had no issues with them fitting me at all!
one cruise ship at a time!
Best Answer02-06-2021 16:33
02-06-2021 16:33
Thanks @DramaQueenDiva,
I did find some extenders that will be here Monday. Hopefully they will work well.
Best Answer02-07-2021 07:12
02-07-2021 07:12
Have same problem with large wrist band that came with my Versa 1 and with Versa 3 which I just bought. The solution for the Versa 1 was a metal wrist band with a magnetic clasp ordered from Amazon that allows for larger wrists and a more precise fit that with conventional bands. Have just ordered a similar metal band for Versa 3 and will coment on how well it works
Best Answer02-08-2021 13:29
02-08-2021 13:29
My new metal wrist band for my Versa 3 just arrived and works well- leaving 1-2 inches spare room after it was connected
Got it from Amazon for under $20
TEWIN Metal Band Compatible with Fitbit Versa 3
Best Answer02-08-2021 14:09
02-08-2021 14:09
hi Pugsleyb,
It looks like they don’t ship to the US. I added it to my cart and it said it was in CDN$ and can’t be shipped to my selected address. Thanks anyway.
Best Answer02-08-2021 14:27
02-08-2021 14:27
02-08-2021 18:19
02-08-2021 18:19
Thanks Rich that is basically what I came up with. The description of the one I bought said I can remove up to 3 links so I figure I can add 3 links... worth the cost of a second band.
Best Answer05-04-2022 19:01
05-04-2022 19:01
I have about a 10 in wrist did adding the 3 links work? Could u add more then 3 if u had to?
