12-10-2019 12:37
12-10-2019 12:37
I shutdown my tracker when I know I will be busy for a while and not able to wear it. Any button used to restart the tracker. Now I have to do a full reset to get it to restart, about 15 seconds. This changed in version 32.70.7.14
12-11-2019
08:36
06:59
12-11-2019
08:36
06:59
@BugsyBob Welcome! Thanks for being part of our Community!
Thank you for your input about the restart. The official restart instructions can be found here but if you wish to have a shorter way then you can share your idea in our Feature Suggestions board. Search for the idea first to see if one already exist so you can add your vote. The more votes an idea gets the more likely the developers will try to implement it.
Let me know how it goes.
12-17-2019 09:22
12-17-2019 09:22
@AlvaroFitbitHello, the concern is not in regards to restarting the device. Instead it is in regards to functionality the Versa had. After shutting down the Versa from settings>about>shutdown it could be turned on/waked by pressing any button. After firmware 32.70.7.14 and after a shutdown the Versa no longer turns on by pressing any button. I am having the same issue as well; this appears to be a bug. Please advise.
Thank you.
12-27-2019 07:42
12-27-2019 07:42
Also after the update, it seems that my Versa drains battery rather drastically.
02-24-2020 21:09
02-24-2020 21:09
Same issue here with my Versa, with many other similar feedbacks in the forum since last firmware update. My Versa now drains the battery twice as much when I turned it Off, than to just leave it On overnight - first time in my life that I own a battery device that behave this opposite way! There was obviously some bugs in the last update which affected all Versa users.
@AlvaroFitbit Fitbit should acknowledge firmware bug and correct it asap, or provide roll-back steps.
