Versa Band replacement parts
Is there anywhere to find the slide peice for the band? Mines cracked and won't last long.
3 REPLIES 3
Im not sure what OS ment by slide pieces @Smmrstanley .
Are these the watch band pins?
If so you could contact support,  by a cheap band off Amazon,  or get a replacement from a jewelry store.
This is the peice I need replaced.
*~Summer Stanley~*
@Smmrstanley  I set no
Is this the piece.
Any good jewellery store will have pins for watches that will work.  They will not have the quick release but they will work.
Or buy a third party band they ate only av few dollars.
