01-15-2020 21:33
01-15-2020 21:33
Hi, the black silicone bands that came in the box with my fotbit versa don't fit on the device for some reason?? Anyone experiencing the same thing??
01-15-2020 21:47
01-15-2020 21:47
Reach out to customer support. Their phone number is (877)623-4997 between the hours of 4am-8pm PST Mon-Fri, and 6am-5pm PST on weekends, if you're in the USA. The phone number to call from the UK is: 0800 069 8505. Operation hours: 9:00am - 6:00pm. If you're not in the USA or if you prefer an online chat or email, then click for contact options
01-23-2020 09:30
01-23-2020 09:30
Had the same problem with the silicone bands. They are very hard to squeeze into the slot. After several attempts I warmed up the silicone under very hot water first (makes it a little more pliable). Then you have to hold the band against the watch at a 90 degree angle. Fit the side without the latch into the hole and then pull down the latch and squeeze in the other side, pushing hard into the slot. Took a couple tries but it finally worked. A lot of work to go through but I finally got it. Good luck.
