12-30-2018 12:06
12-30-2018 12:06
I am disgusted trying to listen to music on my Versa. I have paired several earphones over and over and always the music played jumps around and skips horribly. I have reset Versa and done everything I can think of. Can I get a solution or I have to return this. Very poor performance.
By by the way all earphones used pair and perform perfect on other devices.
Please help.
Best Answer12-30-2018 23:04
12-30-2018 23:04
@Kwpete A few questions:
Best Answer12-31-2018 06:32
12-31-2018 06:32
Best Answer12-31-2018 10:33 - edited 12-31-2018 10:34
Hey @Kwpete, there are some users that are experiencing connecting issues with third party headphones and their Versa, like static, loose connection and so on. Please note that our team is aware and working towards a solution.
Thanks for your help @Marrrmaduke!
I will appreciate your time and patience!
12-31-2018 13:31
12-31-2018 13:31
Best Answer12-31-2018 14:11
12-31-2018 14:11
Best Answer12-31-2018 14:17
12-31-2018 14:17
@Kwpete Don't invest in anything expensive until you test. Perhaps you could borrow from someone. I have Bose SoundSport Wireless and love them. Don't get Beats.
Best Answer12-31-2018 14:37
12-31-2018 14:37
Best Answer12-31-2018 14:42
12-31-2018 14:42
@Kwpete Thanks! 😄
Best Answer01-03-2019 08:59
01-03-2019 08:59
Best Answer01-03-2019 12:52
01-03-2019 12:52
@Kwpete Just a silly question, as most of earbuds on the market will allow for pairing to only one device at a time, have you reset them BEFORE attempting to connect to Versa? Reset, put in the pairing mode and try to connect?
Best Answer01-03-2019 14:11
01-03-2019 14:11
Best Answer01-07-2019 02:43
01-07-2019 02:43
I guess I will give up. I have additional features that operate sporadic now. My opinion is either a faulty device or software is faulty. I can not recommend this product to others.
Best Answer01-07-2019 18:33 - edited 01-07-2019 18:34
@Kwpete really sorry to hear that. I know that there are some brands like Airpods and Beats that have been problematic, but it's indeed weird that all tested buds fail. I would try one more thing before reaching out to Customer Support:
Sorry, I couldn't help more.
Best Answer09-10-2019 21:22
09-10-2019 21:22
I believe this should put an end to the horrible music reception on the Fitbit Versa, once and for all:
JLAB JBuds Air,
Signature Series,
True Wireless
$49.95
Best Answer05-19-2020 08:17
05-19-2020 08:17
I didn't have any issue with bluetooth headphones and Versa for nearly six months. Everything worked fine until the most recent firmware upgrade. Ever since then the music has been choppy/skipping as being reported by everyone else. I've tried two different headphones and no change. Like others have reported, if there is ANYTHING in the way between the fitbit and the bluetooth device (ie my arm), the music is choppy/skippy. If I turn my wrist (so there is literally a line of sight between the fitbit and the headphone), music fine.
I'm not sure what was in the latest firmware, but they need to roll it back to take care of this issue.
Best Answer05-19-2020 12:49 - edited 11-28-2023 01:34
Hello @Hooah, thanks for stopping by in the Community Forums. I'm sorry to hear that you Bluetooth headphones are no longer connecting to your Versa.
I appreciate the details mentioned and the troubleshooting you tried prior to contacting us. We’re aware of it and are working to identify a resolution as quickly as possible. We're sorry for any trouble. We appreciate your patience and look forward to getting you back on track.
I had a similar experience with my Ionic a few months back, so I'd like to suggest to try the steps that worked for me. So, please turn off Bluetooth on your phone while listening to music on your smartwatch, or any other device the headphones might be paired with.
My headphones were paired with my phone as well as my Ionic. I was running out of the zone for my phone. Not so much an Ionic issue, as the way my headphones handle loosing connection to a device. I've removed the pairing to my phone and since then I'm all good.
Please let us know if there's anything we can do to assist you in the meantime.
05-19-2020 13:05
05-19-2020 13:05
Thank you for the quick response MarreFitbit.
I have tried turning off the bluetooth on my phone and that did not help. Also, when I am out running, I am well outside the range for my headphones to connect to my phone.
Like I said, the ONLY way I have been able to keep the music from stuttering is to keep the Versa in a line of sight with my headset, which basically means I have to keep my left are somewhat in front of me, with the palm facing down. As you might imagine, that is not a good or efficient running position.
It was working just fine until I had to do a firmware upgrade to the Versa a week or two ago. So, maybe the engineers can figure out what in that firmware upgrade is causing the issue and reverse it.
Thank you and I look forward to the fix.
Best Answer05-19-2020 13:17
05-19-2020 13:17
Best Answer05-19-2020 13:18 - edited 10-14-2023 09:13
You're welcome @Hooah! Thanks for getting back and the details provided. I'd like to give thanks for the feedback you've provided towards our product and the firmware update. Please know that we provide feedback to our team based on community posts and we are always working on improving our devices and overall environment based on that feedback.
