Versa : Can we get alarm during sleep mode?
Hi,
Just noticed that auto-sleep mode is not working although I Set DND on Moto Z3 Play after updated. Tried to find a solution and for now, I have to set Sleep mode customize.
My question is If I set Alarm early time than Sleep mode customize, I will get alarm vibration or need to cancel sleep mode.
Any help is appreciated.
1 REPLY 1
@Ta_y It's nice to see you on the Community. Sorry for the delayed reply.
Thanks for the details mentioned. I'll be happy to clarify your inquiry.
If you set your alarm before your sleep schedule turns on then it will vibrate. Sleep Mode doesn't automatically turn off unless you set a Sleep Mode schedule. To schedule Sleep Mode to automatically turn on during certain hours, open the Settings app and tap sleep mode > schedule. Sleep Mode automatically turns off at the time you schedule, even if you manually turned it on.
Additionally, if your Versa isn't tracking your sleep, please try the tips mentioned in this article: What should I know about sleep stages?
I'll be around if you have any additional questions.
