11-21-2018 03:24
11-21-2018 03:24
The charger provided with the fitbit versa doesn't allow you to press the necessary buttons to restart it. Any suggestions? I've looked around and I can't find a compatible charger for the versa that allows me to access to the buttons.
Best Answer11-21-2018 03:37
11-21-2018 03:37
The Versa doesn't need to be on the charger in order to restart it, unlike some other fitbit models.
The versa is restarted by:
11-21-2018 03:53
11-21-2018 03:53
I'm talking more of needing to do a hard reset to factory. The screen went blank. I know the device is charging/charged because you can see the green light emitting from the bottom of the fitbit
Best Answer11-21-2018 04:15
11-21-2018 04:15
A standard restart would be a better thing to try first but if you want to factory reset it then it will be a problem with no screen. The manual says:
"A factory reset erases all apps and personal data from Versa, including cards you added in your Wallet. If you want to give Versa to another person or wish to return it for a refund, first complete a factory reset: On Versa, open the Settings app ( ) > About > Factory Reset."
from: https://staticcs.fitbit.com/content/assets/help/manuals/manual_versa_en_US.pdf
11-21-2018 06:41
Bronze Community Members are highly active users who have shared their knowledge for the betterment of Fitbit products and services. Learn more
11-21-2018 06:41
@SteveH wrote:A standard restart would be a better thing to try first but if you want to factory reset it then it will be a problem with no screen. The manual says:
Best Answer11-21-2018 09:30
11-21-2018 09:30
A factory reset will remove the tracker from your account and delete any unsynced data along with voiding Fitbit pay.
On the watch, hold all three buttons for about twelve seconds. This triggers the 2-button hardware reboot after about eight seconds.
- When the Fitbit logo appears, then disappears, release the bottom right button, then continue holding the left and top right buttons until you feel a strong vibration. This indicates the factory reset was initiated.
- This process may take several seconds, and eventually, the Fitbit logo appears and the device boots and displays go to Fitbit.com/setup.
- If you fail to release the bottom right button in time, or otherwise don't follow the procedure precisely, the Fitbit logo reappears quickly and boots without factory reset.
