12-28-2018
23:03
11:55
DavideFitbit
12-28-2018
23:03
11:55
DavideFitbit
I’ve just switched from Alta HR to Versa which I think is great however GPS seems to take so long to connect. The quickest it’s connected so far is 8 minutes. Should it really take this long?
12-28-2018 23:59
12-28-2018 23:59
No, it usually takes about 30 seconds for me for the Versa to initially connect to the Smarphone in "connected GPS" mode. But then it keeps losing connection every few minutes, making the feature useless and unreliable.
Best Answer12-29-2018 00:41
12-29-2018 00:41
Once connected I don’t seem to have a problem it’s just getting connected I’m having issues with. So frustrating as I’m sure your problem is too
