02-25-2019 10:55
02-25-2019 10:55
Hi got my new Versa today. Run bit exercise bike with HR about 120-130 but Versa showed only 70-90 ppm.
Tryed several location on my wrist, but it did not help...
I have also used Ionic Adidas version and with that HR was quite close same as the exercise bike. Bit off at low end but no nearly bad as this Versa.
I am using one of the custom display, may that effect something ? or is the clock itself defected ?
Clock version is 32.33.1.30
Shoud i send it to repair somewhere, under warranty or what the do with it ?
02-26-2019 03:49
02-26-2019 03:49
Thanks for the tip.
Sorry to say, but it did not help, still ~20-30 ppm too low reading when comparing other HR monitors
(resting ppm seems to be quite all right tough)
Anyway, i have no time or interesting to wonder with these device, they either work or not.
So i have returned this back to the shop and bought Polar Vantage v instead.
Thank you
Jari
02-25-2019 13:27
02-25-2019 13:27
Hi, try restarting your Versa several times in a row by pressing and holding the left and right lower buttons together untill you see the Fitbit logo and release the buttons.
02-26-2019 03:49
02-26-2019 03:49
Thanks for the tip.
Thank you
Jari
