Versa- Heart rate monitor not working and battery draining
In few day( since I up dated the Versa) my fitbit isnt lasting a day after its fully charged and the light on back and Heart rate monitor has stopped working. Might be coincidence that I updated it last wee and it had stopped working.
Anyone have an ideas or is my Versa slowly giving up the ghost?
Thanks 🙂
6 REPLIES 6
Hi @Banana2406 , restart your Versa three times by pressing and holding the left and right lower buttons together untill you see the Fitbit logo. If that does not solve your problems, go to the settings of your Versa and turn HR off and repeat the above procedure and after that switch your HR to on again. Regards kuzibri
Hi, thanks for replying.
I gave that a bash and still no heart rate monitor or green light on back 😞
Hi, time for you to call Customer Support to report your problem. Is your Versa still under warranty? Regards kuzibri
have you checked your heart rate setting @Banana2406 the last firmware i installed turned my heart rate off.
Hi, yes I have. Switch on and off.
I have had it since about 2017. So imagine warranty has ended long ago 😞
