02-23-2020 17:49
02-23-2020 17:49
Yesterday my versa lite can't swipe smoothly and automatically switch off during half battery status. Fitbit app is still show not connect device and I can't switch on the device with continuously press the left button. Please advise.
02-24-2020 11:55 - edited 02-24-2020 12:03
Welcome to the Fitbit Community, @StephWong.
I appreciate your participation in the Forums and sharing the details of the issues you're experiencing with your Versa Lite. Thank you for your efforts to resolve this. If the button is unresponsive, I recommend trying to remove dust or dirt by gently using a toothpick around the button. If this does not improve the button performance, you can try to clear debris using canned air. Hold the device at arm's length and spray once to loosen any dirt or dust that may have accumulated around the button.
I also recommend doing the following:
If the device is showing as not connected, please verify if your watch is paired to your Fitbit account. You can confirm the steps to set up the watch here.
If you're experiencing issues with the heart rate sensor, please check this help article.
Please keep me posted, I'll be around.
