11-10-2020 00:07 - last edited on 11-11-2020 19:25 by LiliyaFitbit
Verse lite battery keeps draining within a day from a full charge. I have tried the several reset step and nothing has changed. I have only had this watch since feb this year ? Please help?
many thank
11-10-2020 03:09
11-10-2020 03:09
I am having the same issue I’d really like to know what helps if you are able to fix it?
11-12-2020 10:10
11-12-2020 10:10
Welcome to the Fitbit Community, @emmamcdonald @AngeVersa.
@emmamcdonald I am sorry to hear your Versa Lite battery is draining faster than expected. Thanks for trying to resolve this, I appreciate the additional details and I am here to help. Upon checking with our Support team, I was told that you have already contacted them. I know they will be glad to help you out and provide a solution. I recommend to continue working with them since they have already all the details and special tools to continue assisting you.
@AngeVersa Thank you for sharing that you're experiencing the same issue. I recommend double checking our charging instructions and trying our tips for preventing battery drain since battery use is affected by various factors and settings.
Let me know how it goes.
11-12-2020 11:00
11-12-2020 11:00
Hi ange. I will let you know the outcome as the support team are trying to help me resolve it at the min. Although I find the more active I am the quicker the battery drains ?
regards
emma
11-12-2020 11:03
11-12-2020 11:03
Thank you, I will keep the post posted as and when I get a solution to it as it seems the more active the quicker the battery dies. Picking the time to mention during UK national lockdown was prob not a good time as very restricted. So once I can resume fully I will try what they’ve said and report back to them
kind regards
Emma
11-12-2020 18:28
11-12-2020 18:28
Thank you for your response, @emmamcdonald.
I appreciate the update, thank you for working with our Support team on this issue. I am sure they will do their best to help.
I'll be around.
