12-12-2019 12:23 - edited 04-27-2020 11:08
Fitbit Update: 4/27
Hi, Versa Lite Fam!
Today we're announcing a new firmware: Fitbit OS 4.1.2(version:70.7.27), which addresses and solves the firmware update issue that was identified and reported in this thread. Please update to this new firmware once you see the update banner inside of the Fitbit app.
If you attempt this new update and have issues, PLEASE FOLLOW these step by step instructions in this article: Why can't I update my Fitbit device?
DO NOT ever attempt a factory reset as a troubleshooting method for Versa Lite. Thank you all for your patience while a fix was put in place.
Fitbit Update: 12/12
Hi Versa Lite users,
If you recently purchased a Versa Lite, or if you recently tried completing a firmware update and had issues our teams are aware of the problem.
We're currently investigating and working on a resolution. Please DO NOT perform a factory reset on the watch as a troubleshooting method.
Instead, try the following:
As a side note, if you encounter any issues while updating it, please perform the troubleshooting mentioned in this article: Why can't I update my Fitbit device?
Thanks for your understanding and cooperation while we work hard on a fix.
Best Answer01-30-2020 07:19
01-30-2020 07:19
Best Answer01-30-2020 12:05
01-30-2020 12:05
Best Answer01-31-2020 06:22
01-31-2020 06:22
We shouldn't have to be patient, it should work out of the box. It isn't like Android is some kind of new OS.
Mine did some kind of update last night, but it still doesn't get notifications from my phone. I am fed up and it is going back to Amazon. If all I wanted was a step counter, I could have got that for $20. I will go back to Samsung and know that it will do all the things it is supposed to.
01-31-2020 12:46
01-31-2020 12:46
Since Samsung also makes the phone @HareBall11 I'm sure it will work.
However both Fitbit and Garmin do not make phones and is the reason both put out a list of tested and known phones that work. I'm most cases it is not the OS but the hardware that causes the issue.
Best Answer01-31-2020 12:54
01-31-2020 12:54
Best Answer02-01-2020 02:18
02-01-2020 02:18
I had already attempted a factory reset before reading this post. I had my Versa Lite for Christmas. Two weeks ago I had an alert to complete a firmware update, it won’t complete an update, it keeps saying I need to sync the device and try again. I’ve tried uninstalling device and reinstalling. Also reinstalled the app. Basically I cannot do anything with this fitbit and it doesn’t work
Best Answer02-01-2020 04:00
02-01-2020 04:00
Best Answer02-01-2020 04:21
02-01-2020 04:21
Touch screen on the watch face stopped working
Best Answer02-01-2020 05:40
02-01-2020 05:40
Best Answer02-01-2020 05:44 - edited 02-01-2020 06:52
I don't have bluetooth on my computer, so how am I supposed to connect to my watch from it. The computer doesn't recognize the watch.
Edit to add this:
I got mine working. This morning I decided that I couldn't do anymore damage, so I factory reset and went through the whole setup again. After I downloaded the updates, things still weren't working, but I started to dig around and came across notification settings that I haven't seen before and it seems nobody has bothered to tell anyone about. All mine were turned off! I went through and set which ones I wanted notifying me and after I got through, they all worked. I know this isn't going to help some of the folks, but it will the ones like me who just needed notifications. Below is where the settings are.
Open your fitbit app and open your account by tapping the icon in the top left. Where it says device hold down on Versa 2. In the next screen scroll down to Notifications under General. Then in that screen tap App Notifications. Go through those and choose what apps you want to be notified by.
Best Answer02-01-2020 07:21
02-01-2020 07:21
Trying to update the firmware since 4 days. Fitbit device fails to sync and a message pops up stating data not cleared, sync and try again.
Best Answer02-01-2020 07:35
02-01-2020 07:35
Best Answer02-01-2020 11:23
02-01-2020 11:23
I am facing the same issue. Very disappointed with this kind of service
Best Answer02-02-2020 11:27
02-02-2020 11:27
Mine is 5 months old and it dosent work well at all and no luck with there warranty.
Best Answer02-02-2020 11:34
02-02-2020 11:34
02-02-2020 16:32
02-02-2020 16:32
They are telling me the update will fix mine sounds like crap to me
Best Answer02-02-2020 17:03
02-02-2020 17:03
02-02-2020 17:11
02-02-2020 17:11
I turned off my auto updates since this all happens. I see there is another update. I have not read anything here that it has been fixed. Waiting to hear before I run this.
Best Answer02-03-2020 00:32
02-03-2020 00:32
02-03-2020 12:28
02-03-2020 12:28
