12-12-2019 12:23 - edited 04-27-2020 11:08
Fitbit Update: 4/27
Hi, Versa Lite Fam!
Today we're announcing a new firmware: Fitbit OS 4.1.2(version:70.7.27), which addresses and solves the firmware update issue that was identified and reported in this thread. Please update to this new firmware once you see the update banner inside of the Fitbit app.
If you attempt this new update and have issues, PLEASE FOLLOW these step by step instructions in this article: Why can't I update my Fitbit device?
DO NOT ever attempt a factory reset as a troubleshooting method for Versa Lite. Thank you all for your patience while a fix was put in place.
Fitbit Update: 12/12
Hi Versa Lite users,
If you recently purchased a Versa Lite, or if you recently tried completing a firmware update and had issues our teams are aware of the problem.
We're currently investigating and working on a resolution. Please DO NOT perform a factory reset on the watch as a troubleshooting method.
Instead, try the following:
As a side note, if you encounter any issues while updating it, please perform the troubleshooting mentioned in this article: Why can't I update my Fitbit device?
Thanks for your understanding and cooperation while we work hard on a fix.
Best Answer12-16-2019 12:17
12-16-2019 12:17
I'm having touch issues too, and slow response times, and problems recording my workouts, and problems with my GPS connection. I regret this latest update!
Best Answer12-16-2019 13:37
12-16-2019 13:37
12-16-2019 14:50
12-16-2019 14:50
12-16-2019 17:18
12-16-2019 17:18
When is FITBIT going to fix the update issue. My vera lite no longer works and it was working fine before the firmware update. Now it resets constantly and touch screen no longer works. So now I have a watch that worthless and very expensive. WHEN are you going to fix the issues you caused with the update.
12-17-2019 02:15
12-17-2019 02:15
I was unaware of these solutions and factory reset my versa lite and it is not working. What should I do?
12-17-2019 02:16
12-17-2019 02:16
This is the worst update. My Battery life almost few hours. Also a lot of synchronizing issue i have to restart my Versa again and again. I want Fitbit guys to fix this ASAP, otherwise it will be a bad impact on Fitbit as company.
12-17-2019 02:24
12-17-2019 02:24
I am hitting the point of wanting a refund becuz this is ridiculous.
12-17-2019 11:36
12-17-2019 11:36
I have the same problem, did you have any luck? Would you help me?
Best Answer12-17-2019 12:26
12-17-2019 12:26
I recieved this answer from Fitbit Support, and it helped a lot:
Best Answer12-17-2019 16:18
12-17-2019 16:18
Best Answer12-17-2019 20:23
12-17-2019 20:23
12-18-2019 04:10
12-18-2019 04:10
Best Answer12-18-2019 04:50
12-18-2019 04:50
Best Answer12-18-2019 05:43
12-18-2019 05:43
My Versa Lite battery is currently lasting for about 30 hours. Now, it doesn't even turn on when I turn my wrist and just blips really quick when I push the button to see the time. I just got this a month or two ago. It was fine until about five or so days ago.
12-19-2019 15:45
12-19-2019 15:45
Fitbit why can't you roll us all back to the version that was working before your last update that turned all our Fitbits into useless bracelets. This is so frustrating that instead of rolling back you are trying to fix and can't tell your customers when it will be fixed. Some of us use your watch for health reasons and now we have lost that ability due to your issue. Please either fix the new update or give us the option to roll back to the version prior that seemed to be working. I could care less that the new update give me the option of 5 clock faces, I want my watch to do what it was doing prior to your last update. This is not good for you especially during the Christmas season as you can bet people are telling family and friends not to buy a fitbit as it doesn't work and we are not getting any service for this issue. So disappointed in FITBIT.
12-20-2019 00:16
12-20-2019 00:16
I just came across this post now. In my multiple attempts to resolve the issue (which is still not been resolved), I had to factory reset my device and that was the solution to a different problem (lagging after the new firmware update).
Now that my device hasn't been up for over a day, I don't care as much about how much longer it would take to get the firmware updated but I do want to know if my data is wiped.
I had synced the device with the app before performing the factory reset
Best Answer12-20-2019 03:32
12-20-2019 03:32
After doing the update my watch face is not working at all. I cannot scroll to the next screen to log exercise or update alarms. What can I do??
12-20-2019 05:30
12-20-2019 05:30
Hi, I would like to ask what is the issue with the new update for Versa Lite? My watch will not update whatsoever the screen is blank with only the fitbit logo coming on. It’s very strange. It is connected to the phone but will not update and can’t get onto main screen the only words flashing up is telling me to install the fitbit app? This is very frustrating! Spent so much money and it literally has only given me bother since I got it 🙄 Hope you can help me.
12-20-2019 05:40
12-20-2019 05:40
I had this issue it just would not update on my phone at all. I downloaded the fitbit app on my laptop (Windows 10) and connected my fitbit to my laptop Bluetooth and updated that way. It still took a while but actually worked.
Best Answer12-20-2019 07:42
12-20-2019 07:42
Unfortunately I do not even have a laptop so that is not even possible for me. Hope they fix the issue it’s so annoying!!
