08-16-2020
11:24
10:05
08-16-2020
11:24
10:05
Hi there
since going for a short swim in a pool on holiday my Versa lite is completely dead. I have tried to reset it, I have charged it and although the App tells me it is charged, it is completely black and not connected, the App cannot find it.
Please can anybody help?
Best Answer08-17-2020 10:12
08-17-2020 10:12
Hi there @ADunsmore, welcome to the Community Forums. Thanks for the details shared in your post about your Versa Lite's behavior after swimming. I appreciate you've already taken the time to troubleshoot your watch prior to posting here.
Does your Versa Lite vibrates when you connect it to the charger? Do you still see the green lights flashing on the back? If you haven't done so yet, I'd recommend trying the steps below:
In regards to the full battery percentage on your Fitbit app, note that the Fitbit app updates the battery level every time you sync your watch. Since you haven't synced it yet, your app still remains the battery percentage of the last synced.
I'm looking forward to your response, keep me posted.
Best Answer08-18-2020 04:41
08-18-2020 04:41
Thank you for getting back to me.
I am afraid I have tried all of the suggestions given, I had also looked at other posts from people having similar issues, and nothing has helped.
The screen does not light up anymore, there is no flickering light at the back and the watch doesn't vibrate when plugged in, it's completely dead. Any other suggestions?! Many thanks.
Best Answer08-18-2020 06:31
08-18-2020 06:31
Hey @ADunsmore, thanks for getting back and for the update. I appreciate you had followed the tips and recommendations provided above. Since this sounds a bit more serious, I've created a support case on your behalf - you should receive an email from Customer Support at the email you used to register with the Community forums. Note that we may take a bit long to get back to you since due to recent events affecting our operations, support options are limited and wait times are longer than usual. If you have any questions, don't hesitate to let me know.
Best Answer12-02-2022 07:14
12-02-2022 07:14
Same thing happened to me today, any advice?
Best Answer12-02-2022 15:18
12-02-2022 15:18
Same thing happened to me after swimming in a pool. App shows Fitbit synced, fully charged, no flickering lights on back of device. I have tried all suggestions without success. 😥 I love my Fitbit!
