06-27-2020
19:24
22:58
RicardoFitbit
06-27-2020
19:24
22:58
RicardoFitbit
I noticed today that the green sensor light on my versa lite is not working. I have tried restarting the device and even resetting the factory settings. There light is still not turning on. I checked when I purchased it and of course it's out of warranty by a month! Is there anything else I can do? I've only had it a year! It should las longer. Please help!
Best Answer06-27-2020 22:58
06-27-2020 22:58
Hi @NikkiC823, welcome to the Community Forums!
Thanks for bringing this to our attention and for trying some troubleshooting steps before to posting over here. To resolve this issue and if you haven't already done so, I recommend you to check our help article: Why don't I see my heart rate on my Fitbit device? and let me know how it goes. Such information was really helpful for other users that were experiencing the same uncommon behavior.
Looking forward to your reply, let me know if you have any additional questions.
Best Answer06-28-2020 06:39
06-28-2020 06:39
Hi thank you for responding. I have checked that link out and unfortunately the green sensor light is still not coming on.
Best Answer06-28-2020 06:55
06-28-2020 06:55
Mine is doing the same thing. I have restarted several times, an factory reset once. The light will turn on but will only be on for about 15 minutes. I have tried switching wrist bands, arms etc.
06-28-2020 18:14
06-28-2020 18:14
Welcome aboard @CAusen54 and thanks for your reply @NikkiC823.
Thanks for troubleshooting your devices with me. I've contacted our Customer Support team and created cases for both, they'll continue assisting you with your Versa Lite devices. Please keep an eye on your email inboxes because they'll be in touch with you soon.
I'll be here if you need anything else.
Best Answer06-29-2020 14:17
06-29-2020 14:17
Thank you! I actually contacted CS this afternoon and they were able to help! My HR sensor is now working properly!
06-29-2020 15:18
06-29-2020 15:18
Thanks for your update @NikkiC823.
I'm really happy to know that your issue was resolved after receiving assistance from our Customer Support team. Please do not hesitate to contact me back if you require further assistance in the future or if you have any additional questions for me to answer, I'll be here ready to help you out.
Thanks for being part of the Fitbit family, it was a pleasure to assist you.
Best Answer07-13-2020 09:12
07-13-2020 09:12
Good morning,
Just a little update, I ended up reaching out to Customer Support and they were not able to solve the issue. Someone else from CS was going to contact me and I have yet to hear. Since then, my issue has seemed to go away after I just let my Fitbit completely run out of battery. Don't know why that would solve it but it seemed to work. Only issue now is my battery seems to only want to last 12 or less hours, any tips on this? I have the Versa.
Thanks
Best Answer07-13-2020 14:03
07-13-2020 14:03
This seems to be a common issue. My second Versa lite in a year is doing the same thing. I am under warranty and nothing is fixing the issue
Best Answer07-13-2020 14:19
07-13-2020 14:19
I am having the same issue, and I am also out of warranty by a couple of months! Have tried reset, factory reset, all the settings. Nothing is working.
Best Answer07-13-2020 16:05
07-13-2020 16:05
IDK if it would work or not, but when I just let mine completely run out of battery then fully charge mine has worked ever since. My only issue now is my battery life is 10-12 hrs.
16:38
10:55
07-13-2020
16:38
10:55
Thanks for your update @CAusen54 and welcome aboard @Achan1279 @Cmandre
I appreciate the information that was shared in your post, it's nice to know that your issue was sorted. Please do not hesitate to contact me back if you require further assistance in the future or if you have any additional questions for me to answer, I'll be here ready to help you out.
@Cmandre Thanks for bringing this to our attention. Our Support team informed me that they already provided you assistance to resolve this situation. That said, I recommend you to contact them back if you require further assistance or if you have any additional questions about the outcome of your case. Same for you @Achan1279.
I'll be around.
Best Answer07-13-2020 18:27
07-13-2020 18:27
I contacted them after making this post, and my issue was escalated. Waiting to hear back, and if they’re able to solve my issue I will definitely share the info! In the meantime I will try draining the battery as suggested. Thanks!
Best Answer07-13-2020 18:37
07-13-2020 18:37
I contacted them back at the end of June and a specialist was going to contact me about the issue, guessing they are pretty backed up. No promises draining the battery to 0/fully charging after will work, but ever since I stopped wearing it let it die, and fully charged it just randomly started working again. Hope it works for you.
Best Answer08-05-2020 07:18
08-05-2020 07:18
my bersa lite is doing the same,, no green light ,, not picking up heart rate,, i have tryed resetting it,, cutting the heart rate on and off ,,, i need this fixed asap
Best Answer08-05-2020 08:47
08-05-2020 08:47
08-05-2020 09:18
08-05-2020 09:18
Mine officially died. After getting it to work after running the battery out, about 3-4 weeks later I get no heart rate CS also offered me the 25% off for a new one also. 1.5 years for $150 watch so also not to thrilled.
