08-10-2019 22:20 - edited 08-10-2019 23:22
I first noticed the touch screen was occasionally not working. Unusually I would connect it with the charger, even if it still had some battery life, and this seemed to fix the issue
Then a couple days ago the screen was completely none responsive. So I did a search and found that a number of people have been having this issue (!?!?). I tried holding the left button until the fitbit logo appeared in order to restart it and the touch screen worked for about an hour.
This time when I tried to restart it, the logo appear for the briefest of seconds but it did not appear to actually restart. Plus, the left button now wasn't working either. Gggrrreeaaattt
If I shook my wrist, the screen would light up but that was the only sign of life. So I checked the forums again and how to do a factory reset. Apparently, one can only do this using the touch screen. Extremely not helpful & frustrating. The solution to the problem can not be done due the problem?!?! (whose bright idea was that anyway?!?! The factory reset should always be a manual trigger)
Anyway... the only thing I could think to do was to let the battery die down and force it to "reset". Once it died and was allowed to recharge the touch screen worked! Eureka!
But, not taking any chances, I went to do a factory reset just in case. Now, it's completely dead. Thanks fitbit for disappointing me a 2nd time and taking my money.
I enjoyed my first, the basic flex and eventually upgraded to the Charger HR. That was disappointing as the flimsy plastic backing came off completely negated the ability to charge. Unless you were willing to stand there holding the charging cable. I superglue it, but eventually it couldn't be glued any more & became useless. I took a little break after that disappointment before looking at other wearable products. I decided to try fitbit one more time and here I am, deflated once more. It would seem that the more advance the tech, the more expensive and cheaply made.
01-31-2021 11:22
01-31-2021 11:22
No, and I'm no longer using Fitbit. I have a Garmin and like it so far
01-31-2021 18:17
01-31-2021 18:17
02-01-2021 09:26
02-01-2021 09:26
They sent me a new one but had the same problem. Out of the blue it finally updated. Worked perfect for a while and
now a few days ago there was another update and had a lot of issues with that. I am still working on it.
02-04-2021 07:16
02-04-2021 07:16
I ignored this at first as it's obvious that you weren't reading my description completely, because this will be the 4th time I stated the BUTTON DOESN'T WORK!!!
First the screen stopped responding then after a restart the BUTTON stopped responding
02-04-2021 07:37
02-04-2021 07:37
I'm having the same problem with my Versa lite. I restarted. I made sure the app was up to date. I fully charged it. The screen goes blank from time to time when I push the button to check for time. I have mine set to manual button since I don't like my watch lighting up when I sleep. Why won't the screen show on my watch? It's been happening for the last week or so. I don't want to factory restart, I've done that before and it sucks. Why is the watch messed up? What are you guys doing over there?
07-19-2021 03:31
07-19-2021 03:31
Hi, is der any solution u received or ur watch is still dead?
Same issue happened to my watch. 😞
07-19-2021 07:45
07-19-2021 07:45
07-19-2021 07:46
07-19-2021 07:46
07-20-2021 12:14
07-20-2021 12:14
01-07-2022 17:43
01-07-2022 17:43
@Kiorbree why does my fitbit versa lite clock face only say selecting and doesnt actually download or load anything on my fitbit.
08-29-2022 17:51
08-29-2022 17:51
I did a factory reset on my versa lite a couple months ago. Then 3 nights ago I turned it on to verify it was working and the setup info came on. So I thought all was good and gave it to someone to use. But the next day they couldn't get it to turn on even. They brought it back to me tonight and I am also having no luck turning it on. I put it on the charger and nothing happens. I have tried everything you suggested here but nothing seems to work
08-30-2022 04:34
08-30-2022 04:34
Hi, mine did this last week. I let it run out of battery then recharged it. It worked but the time was wrong! Today it wont sync, so I remove the bluetooth link now I cant find the link to reconnect.
This is the second fitbit I've had. The last one went blank as well. I contacted Fitbit and they told ne to send it back for a replacement . Apparently they are aware of this happening.
08-30-2022 13:55
08-30-2022 13:55
Yeah I have had an older one replaced, and this one was at a discount due to my last one doing this. I just don't understand how it just up and died overnight after I reset it. Had full battery, was turned off and now won't turn on. Fitbit doesn't care. The more they crash the more money they make due to having to buy a new one.
