11-09-2020
12:15
13:22
11-09-2020
12:15
13:22
Is there a way to brighten the watch face so it is easy to see while outside?
i have a versa lite
Best Answer11-09-2020 12:30
11-09-2020 12:30
Go to settings, you will find brightness, you can change it as (auto, dim, normal, max).
11-09-2020 13:28 - edited 05-11-2024 05:03
Hi there @saralast, welcome to the Community Forums. I'll be glad to help you with your inquiry about increasing your Versa Lite's screen brightness.
Please follow @Qais983's advice and make sure your have Brightness settings either on auto or max (depending of your preference).
Also, verify if by any chance Sleep Mode has been enabled as when you turn on the sleep mode setting:
To schedule sleep mode to automatically turn on during certain hours, open the Settings app and tap Sleep Mode > Schedule. Sleep Mode automatically turns off at the time you schedule, even if you manually turned it on.
You can't turn on do not disturb and sleep mode at the same time.
Best Answer11-09-2020 15:34
11-09-2020 15:34
Best Answer11-10-2020 05:38
11-10-2020 05:38
In your Fitbit device, swipe left you will find settings and all of other Fitbit apps.
You can also easily adjust brightness by control center.
To access the control center on your watch, swipe down from the top of your screen. After your notifications appear, swipe down again to open the control center, and there you can find brightness adjustment tile.
Best Answer11-10-2020 05:50 - edited 05-11-2024 05:03
Hello @saralast, thanks for getting back. To find the settings either for Brightness or Sleep mode you can follow @Qais983's directions or you can find the step-by-step here: How do I navigate my Fitbit device?
Let us know if you have any questions.
Best Answer11-10-2020 06:04
11-10-2020 06:04
Best Answer11-10-2020 06:18
11-10-2020 06:18
Hi @saralast, you're welcome. 😉
