08-03-2020
23:38
04:25
08-03-2020
23:38
04:25
Best Answer08-04-2020 04:41 - edited 10-12-2023 18:19
Hi there @Volontieriov, welcome to the Community Forums. Thanks for the details provided in your post about your Versa Lite's screen that went blank. I appreciate you've taken the time to try fixing it prior to posting here. Nice way to go!
In order for me to better assist you with this, please try the steps below:
If the suggestions don't work and your watch doesn't vibrate when you connect it to the charger, it may be that the battery of your Fitbit is not charging properly and therefore it does not turn on. Said that, I recommend doing the following:
If the above steps don't work, at this point I recommend doing a factory reset (before doing so, make sure to remove your watch from your Fitbit account):
You can follow the steps to set up the device after that: How do I set up my Fitbit device?
