07-10-2020
09:14
05:18
JuanJoFitbit
07-10-2020
09:14
05:18
JuanJoFitbit
my fitbit versa lite has a black screen. no matter what i do i can not get the screen to come on. the tracker is still working and this problem began yesterday before i updated the tracker. I can plug it in and charge it and i can plug it into the computer and see that it is indeed working but the tracker has not screen. seeing as half the reason i use it is for its watch face this makes it very frustration to keep.
05:18
03:28
07-11-2020
05:18
03:28
Hi @Sharea405, it's great to see you in our Fitbit Community. I'd like to follow up and help you with your Versa Lite since the screen is not turning on.
Please restart your Versa Lite as described in this help article. After this, check out if the display of your watch turns on and works properly.
Keep me posted on the outcome.
Best Answer07-11-2020 06:54
07-11-2020 06:54
Best Answer07-11-2020 07:17
07-11-2020 07:17
I have the Versa 2 and the same thing happened this morning.. randomly went black, fully charged, none of the trouble shooting options work!
Best Answer07-12-2020 20:01
07-12-2020 20:01
No one seems to be replying about how to fix this.
07-12-2020 20:22
07-12-2020 20:22
My just went blank shows nothing. Only vibrates when trying to restart it .. very frustrating 😕
Best Answer07-12-2020 21:46
07-12-2020 21:46
I am having the same problem. With a full battery my screen stopped working while hiking. Still vibrates, but just a black screen. I have reset, recharged, synced, updated and nothing has worked. Very disappointed and frustrated that we don’t even have an option to contact customer service. I’ve been wearing a Fitbit for almost 6 years but it looks like I will be making a change.
07-13-2020 03:31
07-13-2020 03:31
Same random thing happened to mine-after just waking up to a black screen. It’s been a few days now, still won’t do anything. Fitbit emailed me & said they are sending a replacement. Mine was only a couple months old. I see so many people with the same issue..
Best Answer07-13-2020 03:52
07-13-2020 03:52
Best Answer07-13-2020 03:55
07-13-2020 03:55
I sent tweets on Twitter & also this forum, until someone responded.. also went to FitBit.com where is says contact us..
Best Answer07-13-2020 06:13
07-13-2020 06:13
Best Answer07-13-2020 12:50
07-13-2020 12:50
Well with all the replies on here and no solution from fitbit, i think i will just start looking for a competitor. I have had fitbit for like 7 years and this versa for about 2 but im tired of the products timing out (or being seemingly bricked) after iv had them for a few years. Id love a replacement but im not being replied to.
Best Answer07-13-2020 12:55
07-13-2020 12:55
Best Answer07-13-2020 13:03
07-13-2020 13:03
That is what is happening with mine too. Everything seems to be working and i can even connect on the app to check the battery level but a black screen makes the fitbit useless.
Best Answer07-13-2020 13:05
07-13-2020 13:05
At least you were offered a discount, im just being ignored. I think ill switch brands after this if they continue to ignor me.
Best Answer07-13-2020 13:11
07-13-2020 13:11
Best Answer07-14-2020 06:09
07-14-2020 06:09
Galaxy, luxini, and other android compatible devices
Best Answer07-17-2020 09:29
07-17-2020 09:29
Is there any fix or advise on how to get my screen to turn back on? Is this a known problem? Should i just give up on Fitbit?
