09-07-2020
18:44
07:09
JuanJoFitbit
09-07-2020
18:44
07:09
JuanJoFitbit
Versa Lite went berserk this morning. The screen wouldn't turn on and was unresponsive to button tap. Then it went to the Fitbit logo startup screen but the logo was squished looking. It stayes on that for a few minutes and went black. It won't do anything now. I don't think its on because its not syncing to the app either. I've tried holding button down 3 times for various times from 10 seconds to 30 seconds and nothing happens.
Best Answer09-08-2020 07:08
09-08-2020 07:08
Hi @Rebekah123456, welcome to our Fitbit Community! I'd like to follow up and help you with your Versa Lite since the screen won't turn on and it just says stuck on the Fitbit logo. By the way, thank you for troubleshooting this issue before contacting our forums.
I'd like you to try a factory reset. To do so on your device, follow the steps below:
Finally, set up your watch from scratch and see if the issue gets fixed.
Keep me posted on the outcome.
Best Answer09-08-2020 09:12
09-08-2020 09:12
The logo disappeared and the screen isn't on at all. When I hold the back button down nothing happens.
