07-10-2022
02:06
14:01
AndreaFitbit
07-10-2022
02:06
14:01
AndreaFitbit
Versa lite stuck on big Red Cross data not cleared sync and try again
04:07
06:37
07-10-2022
04:07
06:37
Hi @vck24r - have you tried in the phone's Bluetooth to forget or unpair the device,
Follow the installation instructions
07-10-2022 18:52
07-10-2022 18:52
Mine too!! I tried restarting watch and phone, force stop on app and combo restart... All the trouble shooting advice on fitbit.. Still dead..
Best Answer07-10-2022 20:20
07-11-2022 08:18
07-11-2022 08:18
Best Answer07-11-2022 08:47
07-11-2022 08:47
If the steps are not working, in the Fitbit App, click profile photo, Help & support, Contact Customer support, they may be able to help with your special case.
07-11-2022 10:01
07-11-2022 10:01
Best Answer07-12-2022 04:54
07-12-2022 04:54
I've been having the same issue.
The only thing that's helped so far, and I'm not yet sure if it will work since it's still loading is deleting the device off my Fitbit app and re-adding it as if its a new device.
Best Answer07-12-2022 05:32
07-12-2022 05:32
07-12-2022 05:43
07-12-2022 05:43
Yes, I tried all the trouble shooting tips. 1. restart watch; 2. Force stop of app and restart watch; 3. # 2 and restart watch and phone; 4. delete device from app, re-install and restart watch; 5. delete device AND app and re-install and restart watch. ☹️
Watch shopping now. Pretty sure Fitbit no longer supports the Versa Lite and their warranty is only 1 year.
