Versa Lite shows condensation and won't turn on
Had my Fit bit for Two years now. Recently quickly dove into a pool and stayed in for a couple of minutes, had my fit bit on. Now it won’t turn on and you can see condensation where the sensors.
Will it dry out and work again or time to invest in another on?
2 REPLIES 2
The waterproof goes after a time, especially if immersed in hot water.
It may revive but probably won't be reliable and will have high battery drain.
Best to let it dry on its left side for some days, before recharging it [which will make the matters worse if wet].
Check for when the condensation has gone before doing anything with it.
Hi there, @Rangers_08. Welcome to the Community Forums. Thanks for sharing the details about the issue with your Versa Lite. I understand where your concern is coming from.
If you have followed @Guy_ steps but to no avail, the best way to get help for this problem is to chat with us online or give us a call. Click here to get connected.
