11-25-2019
07:37
17:53
LizzyFitbit
11-25-2019
07:37
17:53
LizzyFitbit
Yes. I got a virus on my Fitbit Versa Lite. It saw to retry update. I’ve tried many times without success. No other device was affected. No help with messages
Best Answer11-25-2019 08:54
11-25-2019 08:54
@maryb5000 the virus is actually on your Versa Tracker? Or is it on your computer or phone?
Best Answer11-25-2019 10:49
11-25-2019 10:49
It is in my Fitbit. Happened when updating. Worked fun prior to update attempt.
I’m trying to send a picture
Best Answer11-26-2019 05:46
11-26-2019 06:42 - edited 11-26-2019 06:44
That is not a virus @maryb5000 but some requested process not completed.
I did a quick search of the versa board and found several posts that have solution. Including this and this one.
The common points seem to be a restart and setup the Versa as if it is a new device.
I've also moved your Versa question out of the Flex board.
11-26-2019 08:32
11-26-2019 08:32
I have tried that a few times. I was also told it was completed by a Fitbit staffer.
I will try it again.
This is my 3rd type of Fitbit device. I have owned a Fitbit about 15 years. This is very disappointing as is the responses.
Best Answer11-26-2019 10:05
11-26-2019 10:05
Oops a typo I’ve had Fitbit 5 years.
Best Answer11-26-2019 17:51
11-26-2019 17:51
Hi @maryb5000. Welcome to the Forums. @Rich_Laue, great to see you here and thanks for your big help!
@maryb5000, thanks for the picture and your efforts while working on your watch. As our friend @Rich_Laue mentioned, the message displayed on your Versa Lite's is expected to see it when your watch needs to be set up or updated. I understand how you're feeling about this process and since the suggestions posted in this thread didn't help, may I know if you've a Windows 10 computer with built Bluetooth? I'm asking this as we have a different process that may work to get your Versa Lite updated and working again. In case you have access to one, please follow these steps in the given order:
If the issue persists, try the steps described in this help article under Ionic & Versa series > Instructions for installing Windows 10 Driver.
I'll be around, keep me posted.
11-26-2019 18:50
11-26-2019 18:50
Best Answer11-29-2019 13:39
11-29-2019 13:39
Hi @maryb5000. I'm glad to see you here again and I'm sorry for the delay.
Thanks for trying the steps posted above. You did a good job while working on your Versa Lite and I'm sorry that the issue persists. I've checked your details with our Support team and apparently you've a case created with them. They'll continue providing you with assistance via email, so make sure to check your inbox.
I'll be around if you need anything else.
Best Answer02-02-2020 08:22
02-02-2020 08:22
I have the similar issue. Has this been resolved
02-02-2020 09:48
02-02-2020 09:48
Doing a search of the Versa board shows that some resolved this issue burping a factory reset.
Best Answer03-20-2020 21:49
03-20-2020 21:49
Worked perfectly
Best Answer04-08-2020 08:06
04-08-2020 08:06
I have followed all the steps listed and my fitbit Versa Lite still only shows the X and data not cleared. What else can I do to get my watch working again?
