03-16-2021
19:10
14:08
YojanaFitbit
03-16-2021
19:10
14:08
YojanaFitbit
The watch doesn't work, stays in "Data not cleared Sync & try again"
Best Answer03-17-2021 14:11
03-17-2021 14:11
Hi there @Nakasagu, it's nice to see you again on the Community Forums.
Please note the message "Data not cleared, Sync & Try again" usually appears when you performed a factory reset without first unpairing your watch from your phone's Bluetooth settings.
With that being said, please try the following steps to solve the issue:
If you can't get started with your Versa Lite, usually a missing requirement is the cause. Carefully review the requirements provided in the help article Why can't I set up my Fitbit device?
If you continue having issues with your watch's touch screen after pairing it again, try to change your clock face. If this fixes the issue, you can change your clock face back to the original clock face.
Hope that helps.
