10-05-2019
02:17
13:26
DavideFitbit
10-05-2019
02:17
13:26
DavideFitbit
Can you change (increase) size of read out -ie BPM ?
10-05-2019 03:36
10-05-2019 03:36
What device are you using? This will be under its firmware settings.
IOS: Settings - Display & Brightness - Text Size - choose your setting.
I am not an Android user so you will have to Google the answer!
10-05-2019 04:05
10-05-2019 04:05
10-05-2019 04:18
10-05-2019 04:18
Device as in Phone: Android or IOS = Apple phone.
Laptop/PC. Is it a Mac or Windows 10?
It is by far easier to view all stats via the FitBit app on a Mac or a Windows 10 laptop or PC.
Download it for your device from here: https://www.fitbit.com/uk/setup
If you go to support you will get a resolution a lot quicker! https://help.fitbit.com/?l=en_US&cu=1&fs=ContactUs
10-05-2019 19:18
10-05-2019 19:18
@dwmw I'm assuming that your asking about the heart rate display on your versa lite, but is this on the clock settings or in the stats? If on the clock you may have to check the settings.
