Versa Lite starts flashing by itself
ANSWERED
My versa lite screen just starting flashing when I try to view it.  It turns on for a second and then goes blank.  I tried resetting it several times and it works for a minute or so and then starts flashing again.
1 BEST ANSWER
Accepted Solutions
Hi there @Mpiaia, welcome to the Community Forums. Thanks for reporting your Versa Lite's recent behavior and for taking the time to fix the issue prior to posting here.
Since the restart hasn't worked, I'd recommend to do a Factory Reset. Before doing so, please sync your watch and then remove it from your Fitbit account and also unpair it from your phone's Bluetooth settings, then do the following:
  1. Hold the back button for about 8 seconds.
  2. When the Fitbit logo disappears:
    1. Release the button briefly (for less than 2 seconds).
    2. Hold the button again until you feel a second, longer vibration, which indicates you initiated the factory reset.
You can follow the steps to set up the device after that: How do I set up my Fitbit device?
Give this a go and let me know if the screen keeps flashing by itself. I'll be around.
2 REPLIES 2
Thanks! That seems to have worked!
